Auto Populate X Y fields
3079
06-06-2014 01:17 PM
JeffWard
Honored Contributor
Is there a way to auto populate the X Y fields I have in my feature layer when using Collector?
Jeff Ward
Summit County, Utah
MikeBruening
If you happen to find an answer to this question, then it would be great to have some insight...If I happen to find a way I'll revisit and post it here.
SappiGIS
Hi
I have auto populate the fields in SQL server.  You can use a trigger or view by adding the following field to the view/ trigger.
x.[SHAPE].STY AS lat, x.[SHAPE].STX AS long,
It worked for us.
