Attributes location still customizable while options for the function are off
697
10-22-2021 01:03 AM
Kantoor__DataCount_-_Verkeerso
Hello everyone,
I having some trouble with the collector application in cooperiation with ArcGIS Online. I've made a map with some points in ArcGIS Online. I uploaded the map to the Collector application. The Collector app makes it possible to go outside and change the data behind the points. The field worker should be able to only edit the attributes, as you can see in the image down below:
But when I open the Collector app, it is still possible to change the location of the point.
Does anyone know why it is still possible to change the location of the point while the editing mode for the geometry is off? I am using the Collector 20.2.2 version.
