Arc Collector Lat/Long
1131
10-15-2019 06:00 AM
LeifJohnson3
Why are there no latitude longitudes associated with the points I collected in Arc Collector?
RobertBorchert
Honored Contributor
Latitude and Longitude are generated when a point is placed. For most use cases seeing them is not necessary. If you need to make  use of them create X,Y (double) fields and calculate geometry on them.
and the other question would arise and disgruntlement would be which format would they show.  So I it is simply better to let the user generate them as needed.
LeifJohnson3
Thanks so much for the quick reply Robert.  I was able to export the feature layer as an excel and all of the lat/longs were waiting right there for me.  Thanks again for the help.
