Good Morning
Currently collector only allows as a base map the .tpk format
I would like to propose the following idea:
to be able to use from base collector base maps in mbtiles format or the maps downloaded in the Windows Maps application 10.
This functionality would be good, so you only have a downloaded map and avoid problem of hard disk space of tablet.
Thank you so much for your attention
