Unable to import Shapefiles - "Error while reading the file. May be an unsupported shapefile type. See log."
2762
5
07-14-2019 07:42 PM
MichaelMurphy7
eclipse.buildId=unknown
java.version=1.8.0_151
java.vendor=Oracle Corporation
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_AU
Framework arguments: -keyring /Users/michaelmurphy/.ce_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -data @noDefault -keyring /Users/michaelmurphy/.ce_keyring -showlocation
Warning
Mon Jul 15 10:29:27 AWST 2019
java.lang.NullPointerException - [ModalContext]
at com.procedural.formats.shapefile.ShapeImportWizardPage$3.run(Unknown Source)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
ChristianIten
Hi michael,
Can you make the file available so that we can verify?
What CE version do you have?
MichaelMurphy7
Hi Christian,
Thank you for responding. I’ve attached one of the shapefiles I tried importing. Am using CityEngine 2019 Build ID 5403.
Regards,
Michael Murphy MAIA
Principal  Urban Designer
Studio Eco
m: 0438 992 534 t: 08 9454 3017 web: http://www.studioeco.com.au
ZorkoSostaric1
Michael, shapefile has multiple components (files) and you must have all to be a valid shapefile. See specification for details here or just make sure you include all files named Landgate_Road_Segment.* These will be Landgate_Road_Segment.dbf, Landgate_Road_Segment.prj, Landgate_Road_Segment.shx and any other extensions.
Then we can test your shapefile in CE.
Regards,
Zorko
MichaelMurphy7
Hi Zorko,
Please find attached all associated files.
Regards,
Michael Murphy MAIA
Studio Eco
ZorkoSostaric1
Michael,
Very brief response (end of my working day). The shapefile now looks good but it may not be the best suited for CityEngine. Here is how it looks in ArcGIS Pro.
Best option would be road centreline rather than road casing.
