tapering
2210
07-26-2012 03:40 AM
MatthewHarrison
The model I am working needs to include slightly tapered cylinders, and I also require a parameter to control the extent it tapers. Is there a way to either have a tapered extrusion that is not complete (i.e. not to a point), or to alter the inserted cylinder asset easily to make it tapered?
Matt
MatthiasBuehler1
hi !
check the attached files.
using a circle asset ( 20 edges ), then a roof operation, then a split. and some trigonometry.
I assume this works for you ?
cheers !
matt
MatthiasBuehler1
hi !
Sorry for the late reply, I've been in holidays.
Can you post a few pics what precise you need ?
MatthewHarrison
That's ok!
I simply need to insert or create cylinder shapes such as that in the pic attached, where the top is smaller than the bottom, but be able to control both the height (h) and the amount of tapering (x) parametrically. Hope that is clear?
[ATTACH=CONFIG]16475[/ATTACH]
MatthiasBuehler1
hi !
cheers !
matt
MatthewHarrison
Thanks very much,
Works very well.
