Street Creation - open street map
2805
10-17-2013 06:11 AM
LukeCzar
Hi Matthias,
I imported the street file (osm) from www.openstreetmap.org and streets look very bad, I run the cleanup took, but still...
Is there any way to import those streets with original shapes?
Thanks!
[ATTACH=CONFIG]28401[/ATTACH]
MatthiasBuehler1
can you wait for CE 2013 ? :rolleyes:
LukeCzar
That's what I was thinking of 🙂 I heard the new update should fix that problem,
When is it coming out?
I have a presentation in 4 weeks...
Thanks!
MatthiasBuehler1
hi,
there is no such thing as 'original shapes' in osm street data, since the street data only consists on attributed lines.
CityEngine creates the shapes dynamically based on the data available. the issue is that sometimes the input is already not so good, there we cannot do anything. [ osm is free data .. ]
but we've been working on the importers and cleanup tools a lot, so they should do a much better job in 2013.
ok ?
