Stochastic Rule on Heigh
2369
10-29-2014 04:40 AM
IonutAlixandroae
I have defined an "Height" attribute which has 3 specific values.
I want to create a stochastic rule that would give me 33% percent of each height when applied on buildings.
Could someone help me with managing this problem? I tried creating a 'case-else' rule on "height" but it doesn`t seems to be correct...
Eg.
@Range (Random="random", Floor1=5, Floor2=10, Floor3=15)
attr Height = "random"
Building -->
  extrude(world.y, Height)
  Mass
const function_Height =
  case Height == "random" :
  33% : 5
  33% : 10
  else : 15
by Anonymous User
Not applicable
1. Range has mixed data types. Since random is a string, all must be string. Change to:
@Range (Random="random", Floor1="5", Floor2="10", Floor3="15")
2, extrude command should use constant function_Height, not attribute Height. Change to:
extrude(world.y, function_Height)
3. The constant function_Height needs a matching else for the case statement. The else you have now applies to the stochastic structure and not the case. Also the extra else now needs a float function, since your Height attribute is a string and not a float. Change to:
  33% : 5
  33% : 10
  else : 15
  else: float(Height)
