Slope / extrude buildings
4027
8
01-27-2017 08:53 AM
Joao_PedroMarques
Hi!
What is the best way to get building / rooftops aligned?
Like this:
My example:
Is there any command to get the rooftop correctly aligned, regarding the slope on the terrain?
Thank you guys.
Best,
JM
LR
extrude(world.up.flatTop, value)
Joao_PedroMarques
I'm currenty using this cga for the building correct heights (based on geodatabase atrributes) :
#initalize attribute set to a particular value or 0
attr NPisos = 10
attr avgFloorHeight = 3
@StartRule
Lot --> extrude(NPisos * avgFloorHeight)
NPisos is Number of floors.
How can i add that line in my cga? What would be the value?
Thank you
DevinLavigne
Just building off the comment from Rasa Ra  it would be something like this:
attr NPisos = 10
@StartRule
Lot --> extrude(world.up.flatTop, NPisos * avgFloorHeight) ‍‍‍‍‍‍‍
Joao_PedroMarques
Thank you David, but something is missing.
i found the topic in the help faq: Help -
But still cant figure it how to work
BenLeslie1
Are you using CE 2016? - I think flatTop CGA was only introduced at 2016.
When you align shapes to terrain, instead of projecting, use translate to minimum then extrude the building through the terrain.  I don't know if there's another way to replicate flatTop.
Joao_PedroMarques
Hi Ben,
Yes i'm using 2016.1 and even when i use the translate to minimum i get the same result.
ThomasFuchs
Joao Pedro Marques‌ This rule should give you a building on a leveled lot at the minimum of sloped shapes:
attr buildingHeight = 15
@StartRule
Lot -->
     alignScopeToAxes(y) s('1,0,'1)
     extrude( buildingHeight )‍‍‍‍‍‍
Joao_PedroMarques
It worked!1
Tahnk you so much, Thomas!
