Scripted export model per leaf shape
3348
6
08-27-2021 11:09 AM
AndrewDeighton
I need to export some generated models to multipatch format using the per leaf shape option.
I have no problem doing this through the UI, but I need to automate the process.
Is there a complimentary function available in the Python scripting interface to do this automatically?
Tags (4)
JonasObertuefer
Hi @AndrewDeighton,
If I understand you correctly you did use the SLPK Exporter (Export Models -> Esri Scene Layer Package) in the UI. For the SLPK Exporter there is the SPKMeshExportModelSettings() available in the python scripting interface, see:
Hope this helps.
Cheers
Jonas
AndrewDeighton
@JonasObertuefer wrote:
Hi @AndrewDeighton,
Hope this helps.
Cheers
Jonas
Hi Jonas,
Thanks for the reply!
I'm using the FileGDB exporter as it seems to be the easiest 3D format to manipulate in ArcGIS and non-ArcGIS applications.
From the UI, the exporter allows me to set the granularity to "per leaf shape".
I have already scripted the majority of the export in Python, but can't figure out how to set this "per leaf shape" flag in Python using FGDBExportModelSettings().
I should have mentioned I'm using CityEngine 2020 under an advanced license.
Cheers,
Andy
JonasObertuefer
Hi Andy,
Currently the "per layer options" settings of the FileGDB exporter can't be set via the python scripting interface. So, right now the only option to set the feature granularity in python is by using the SLPK Exporter, maybe you can build your workflow around it?
Best,
Jonas
AndrewDeighton
Hi Jonas,
Thanks again for the reply.
I've researched a little into the SLPK format and it seems that with this format, after export I cannot convert to multipatch or any other 3D format that can be interrogated/ manipulated in Python (needed for my workflow).
I've been toying with the idea of converting my .CGA rule files to RPKs and running them though PYPRT and setting the start rule annotation to the following:
@Out (granularity=separatedShapes)
Would this create the desired per leaf shape output?
I have map controlled attributes, would they still function?
All the best,
Andy
JonasObertuefer
Hi again, Unfortunately @Out (granularity=separatedShapes) is ignored by PyPRT. So, I don't see any other option than using the UI exporter at the moment.
海洋2021
I'd like to know that is pyPRT supports @Out (granularity=separatedShapes) now?
