Problem with building`s floors
6679
13
11-20-2014 12:36 AM
IonutAlixandroae
I have created a rule that will generate a building with 4 floors, the second and the 3rd one are L shaped.
If I have no terrain in my scene, everything works perfectly normal, but if I add a terrain to my scene, align the lots to my terrain and assign the rule to them, the extrusion is very weird. I attached a print so you could understand better what I mean by weird extrusion.
I`m not sure if it`s because of the rule or because the lots are aligned to a sloped terrain.
Thanks!
IonutAlixandroae
I understand perfectly
Thank you again !
by Anonymous User
Not applicable
Awesome! I've seen you learn a lot of tricks here. ESRI Romania has a talented CGA author now.
IonutAlixandroae
I`m doing my best to learn everyday something new To be able to create and design models like you guys it`s necessary to work hard and also to be diligence. Would be a dream come true to see the work done at ESRI in Redlands; but who knows, maybe I`m lucky for a UC in next years to come
Thank you again Chris !
DavidWasserman
This looks pretty cool. I feel like investigating cool looking distortions after seeing this. Glad everything worked out.
David Wasserman, AICP
