Open Street Map Import
2360
08-22-2012 11:36 AM
JustinWentz
Hi all,
I've exported an .xml file from openstreetmap.org.  My actual file is called "map.osm.xml".  CityEngine will only allow the importing of files with the extension .osm so it will not import my .xml file.  There is no option on openstreetmap.org to export a file with the extension .osm.  How do I make this work?  I've tried importing the xml file anyway with the OSM import tool but it just won't do anything.  Anyone else already figure this out?
-Justin
MatthiasBuehler1
hi !
just delete the .xml ending so it reads just .osm.
[I've seen this happen on MacOS.]
