import rules
1600
10-03-2019 04:32 AM
BilalMustafa
Hello!
I'm working at a project to modeling a city buildings, my estimated goal is to model each building with its real facade using the facade wizard and I'm doing well so far,  i'm assuming that i can   facade each floor by using the   same procedure but i don't now how
my rule is:
import gen_Facade_AdvancedFacade :"/شارع السهل/rules/gen_Facade_goolge2_cropped.cga"
import gen_Facade_AdvancedFacade1 :"/شارع السهل/rules/gen_Facade_IMG_3451_cropped.cga"
import gen_Facade_AdvancedFacade2 :"/شارع السهل/rules/gen_Facade_السهل 34 ب_cropped.cga"
import gen_Facade_AdvancedFacade3 :"/شارع السهل/rules/gen_Facade_السهل34 ج_cropped.cga"
import gen_Facade_AdvancedFacade4 :"/شارع السهل/rules/gen_Facade_السهل 34 د_cropped.cga"
import gen_Facade_AdvancedFacade5 :"/شارع السهل/rules/gen_Facade_السهل 34 ه_cropped.cga"
import Roof_Textures:"/ESRI.lib/rules/Roofs/Roof_Textures.cga"
/* Attributes *************************************/
attr Roof_Ht =2
attr height = 24
attr groundfloor_height = 5.5
attr floor_height = 4.5
roof_tex = "roofs/roof.tif"
@Order(5) @Range("flat","shed","pyramid","gable","hip","half-hip","gablet","gambrel","mansard","gambrel-flat","mansard-flat","vault","dome","saltbox","butterfly")
attr Roof_Form= "flat"
@Order(1) @Range("realistic with facade textures","schematic facades","solid color")
attr Representation = "realistic with facade textures"
#Function###
getFlatRoofTexture = fileRandom("Roofs/Flat/flat*.jpg")
getSlopedRoofTexture = fileRandom("Roofs/Sloped/ceramic*.jpg")
/* Initial Shape starting rule *************/
# extrude the lot to building height
@StartRule
Lot --> extrude(height) Building
Building --> comp(f) {0:Base|1:Roof|2:AA|3:BB|4:CC|5:DD|6:EE|7:FF|8:GG|9=HH|10=II|11=JJ|12=KK|13=LL|14=MM|15=NN|16=OO|17=PP|18=QQ|19:RR |20:SS|21:TT| 22:UU|23:VV|24:WW|25:XX|26:YY|27:ZZ|28:AB|29:AC|30:AD|31:AE}
BB -->
split(y){ groundfloor_height : Floor(split.index) // Groundfloor
| floor_height : Floor(split.index) // First Floor
| floor_height : Floor(split.index) // Second Floor
| {~floor_height : Floor(split.index)}* // Mid Floors
| floor_height : Floor(999) // Top Floor, indexed with 999
| 0.5 : s('1,'1,0.3) LedgeAsset} // The top ledge just below the roof
Now is it possible to insert the facade generating code with the split function like the one bellow:
BB -->
comp(f) { 2 :gen_Facade_AdvancedFacade3.Facade}
or i have to separate  each function in a separate rule then import the rules and mash them together!
i"m just confused, i read the following questions in the forum:-
cga facade parts
why is my imported rule file not working
importing rules from Other CGA files
and still have no clue,can you please help me to start on the right way
BilalMustafa
Thank you Guys, I fixed my issue
BilalMustafa
