How to put a door model inside a door frame model?
3129
03-09-2016 09:14 PM
ChristianShiel1
How can I insert my door object into the empty space made by the frame? I cannot see how I would split this up.
CherylLau
In your EntranceTile rule, you could separate out a part for the door and frame.  Then, DoorAndFrame creates both the door and the frame.
EntranceTile -->
      split(x) { ~1 : SolidWall
            | 1.5 : split(y) { 2.8 : DoorAndFrame
                             | ~1 : SolidWall }
            | ~1 : SolidWall }
// door plus frame
DoorAndFrame -->
      Door
      DoorFrame
Door -->
      // add code to resize and position as desired
      i(door_asset)
DoorFrame -->
      i(doorFrame_asset)
ChristianShiel1
That worked thanks!
