how to open fbx format
6401
03-30-2016 10:57 AM
ömer_farukakyüzlü
Hi...
I use ArcInfo 10.4
How to open fbx format
Best regards...
DanPatterson_Retired
where did it come from?  did fbx turn up anything as a file extension on google?  You wouldn't mean tbx would you?  if so, you add those to arctoolbox since tbx files contain tools/scripts and or models
AdrianWelsh
MVP Honored Contributor
Hi ömer,
Take a look at this site about importing fbx data:
Help -
Edit: This thread should probably be moved to the City Engine place.
ahhhh ....Open Data... had an interpretative twist to it CityEngine​ bound  Timothy Hales​ I can't move it... could you redirect
TimothyHales
Esri Notable Contributor
Moved to CityEngine
