formula in .cga to choose façade textures with attr from GIS data, filter on year&use
653
02-26-2014 12:32 AM
KennethLindhardt
Now I finally have some time allocated to CItyEngine.
I would like to create a rule file, that I can use to automatically generate 3D buildings with attributes assigned to the building polygons from a geodatabase.
I saw Matthias??? thread ???GIS data mini tutorial??? and it???s almost similar to what I would like, but I face some issues.
I would like to automatically assign textures to my buildings, and it need to change the texture depending on the year the building is from, and the building use. So a building from 1940 to 1960 used as a office, would randomly take textures from folder A. Then a building from 1960 to 1980 used as office, would randomly take a texture from folder B. A building from 1940 to 1960 used as a school would randomly take a texture from folder C etc. but of course with a little more folder structure. Depending on how many building uses the geodata brings this can result in a lot of different folders and a lot of rule typing, but I need some help to get this to work.
When I read the ???GIS data mini tutorial??? it had me start thinking how this could actually be done. If I set a attr to 0, it will take the data given from the GIS data. But this would not work for me, since the attribute is not giving me an information I can actually use.
What my thought was, was to create for example ???attr dateBuilt = 0 (next line) attr buildingUse = 0, but then I would need the rule to actually read the attributes from the GIS data and calculate which folder to choose from. IF dateBuilt = 1943 and buildingUse = school ; lookup folder C.
Has this been done?
Can it be done?
And how is it done? (I only need some guidance not a complete rule;-)
KennethLindhardt
So I thought a little more about this. Maybe it would be smarter to have the calculation done in Python, and make it bring up a value inside a new attribute, like the one I was trying to calculate inside the rule itself. So if I have a new attribute �??façade�?� that are giving me different kinds of values. Then I guess the rule would be a lot easier to manage, but I still need it to look up a specific folder depending on which value the façade attribute gives me. So if the attribute value returns 41 (4 = 1940 �?? 1960 & 1 = school) (just an example) Then I will need the value 41 to randomly take a texture from folder a.
Doesn�??t that sounds a little easier, and it is possible? (Just the rule, not the Phyton scripting)
MatthiasBuehler1
yes, this is possible and has been done e.g. in the Paris Example.
usually, you need to create a few functions that create the logic to find the appropriate texture, using fileRandom() or so.
check the string operations in the CGA reference.
Matt
