exporting to ArcScene
2096
08-30-2012 12:36 PM
JoanneO_Brien
So I've been experimenting with exporting my scene in collada to ArcScene and seem to be running into a problem, when I bring it into ArcScene my buildings become wonky, as shown in the picture below! I think this might have something to do with the elevation layer not being exported to ArcScene with it? Anyway any suggestions on how to fix it?
Thanks!
MatthiasBuehler1
hi !
Collada is not a file format which is designed to port geolocated data due to precision limitation. Use kml instead.
Read this thread carefully, it's basically the same problem :
http://forums.arcgis.com/threads/59442-FBX-export-%28models%29-to-3DSMAX
hope this helps ! 🙂
matt
JoanneO_Brien
I had a look at that but I'm a bit confused now about how to bring it into ArcScene. I cannot bring it in directly or using the Import 3D Files (3d Analyst) tool as it doesn't support KML format. The only other thing I could find was the KML to layer converstion but this just brings it in as a line. What am I missing here?
Thanks!
MatthiasBuehler1
Hi.
There should be ways to import the kml files properly into ArcGIS. I did this a few times by converting ( as you mention ) to a layer. I am not a ArcGIS PRO at all, so you may try to find the answer on this via Esri Support.
Nevertheless : CE 2012 ( due Sept. 12th ) supports textured MultiPatches, so you can directly export your geo to a GDB as MP.
Ok ?
