Combining different scenes
2707
09-24-2013 06:38 AM
denizsenturk
Hi!....
I want to combine two different scenes into one scene.I tried to import one of these scenes into other scene.However,i got the import fail atteched as a screenshot.
What is your suggestion?...
Thank u so much...
denizsenturk
One more thing!...They are in the same coordinate system!...
MatthiasBuehler1
Yes, that should work. Not sure why you get that error.
1] What's the SCS ?
2] Can it be that even though they're the same SCS, one of the scenes has some elements at the cartesian origin ?
3] Can you create copies of the scene file, delete out all layers except 1 layer consecutively, then try importing 'layer cej by layer cej' ?
Lemme know.
matt
denizsenturk
Hi 🙂
I tried these.I think my need can be to carry one of the scenes to other scene's  coordinate.By using scale window,i entered the values where i want to carry the scene and press the 'enter'. However,when i do this,nothing happened.How can i achieve to move a known coordinate?
Thanks.
MatthiasBuehler1
your approach should work.
haha, that's funny. You need to press 'return' to preform the move. weird, I know.
once you have moved the data ( or even before ), you need to delete ALL the other layers which have something near the cartesian origin (XYZ = 0). E.g. that terrain image.
Ok ?
m.
