City Engine inside the Story Map
3629
02-20-2014 04:12 AM
LukeCzar
Hi Matthias!
I would like to use my CityEngine Web Scene inside the Story Map,  I used help option and this link :
http://blogs.esri.com/esri/arcgis/2014/01/21/adding-cityengine-webscenes-to-your-story-map-map-tours...
and still...doesn't work
I created my story map, but when I try to use arcgis online to edit and add "the point with cityengine URL" it says the layer is not editable, how can I add my scene?
Did anyone tried it before?
Lukasz
MatthiasBuehler1
Got a feedback on this :
One of our developers just tried it and it seems to work as described in the blog post: http://bit.ly/MgcSin
But he says it's not a good thing to embed multiple WebScenes in one story map because every time the user clicks next one has to load a new 3ws. So we'd not recommend to do this.
The issue seems to be in the story map itself ..
And an other input:
If you really want to do this??? add "&reducedUI" to the end of the webscene url so that the right panel doesn???t clutter the small view.
ok ?
Matt
MatthiasBuehler1
And an other input:
ok ?
Matt
LukeCzar
Thanks Matthias!!
Lukasz
