City Engine Crash when calling Help
3014
5
12-07-2012 02:19 AM
anthonymagdelaine
hi,
i'm actually working on CE 2010
it worked fine during many days, and sudenlly when i call Help, it loads the windows, then crash at
loading 127.0.0.1:55379/help/advanced views.jsp...
MatthiasBuehler1
Did you try to start CE in safe mode ?
Did you try and create a new Workspace to test this ?
Let me know.
M.
anthonymagdelaine
hi,
i tested CE in safe mode
with existing folder project ---> help crash
with tutorial folder --> help crash
with new empty folder --> help crash again
sometimes the loader goes to terminate before it crash, sometimes not...
MatthiasBuehler1
Ok, then test with a new Workspace.
File > Switch Workspace > Other ..
In there, change the path to something else than the default 'CityEngine' WS. Restart CE.
In CE, you'll see no linked projects. Try then to load the Help. If that does not work, I'd reinstall CE.
Let me know.
m.
anthonymagdelaine
i uninstalled CE then er-installed it after a reboot and it works fine now.
don't know what happened.
thanks
MatthiasBuehler1
Cool. Glad to hear ! 😮
