CGA rules for underground facilities
8061
15
07-29-2015 02:57 PM
awei
I'm writing CGA rules for manholes and pipe lines which connect manholes together. Does anyone have examples of these kind of CGA rule files I can refer to?
Thank you!
awei
Hi Dan,
Then am I able to export the 3D models from ArcMap to CE?
DanielHedges
Yes, the buffered line features will be in multipatch format in your geodatabase. Then you can use File > Import > File GDB Import, and navigate to your new features from there in CE.
awei
Thanks! That worked excellently. Also can you texture those pipes?
DanielHedges
Absolutely. I'll pass it back to Chris Wilkins​, who has put together some simple CGA to texture multipatches. Yo Chris!
by Anonymous User
Not applicable
a wei,
Here is the rule Dan mentions (attached). You might need to experiment with the @InMesh annotation on the start rule if using this in ArcGIS Pro.
Also, you'll need to point the image texture to your particular image.
Chris
by Anonymous User
Not applicable
Update to this post.... I found a couple errors in the rules, which when encountered made things look really bad.
Here's a fixed version of the Manhole (attached).
