Can CityEngine be Used for Infrastructure Projects
1382
10-28-2011 02:31 PM
AndyTan
can we do below ground models eg tunnels . metro lines in city engine ? all the example shown here are above ground.
MatthiasBuehler1
hi !
for the CityEngine, geometry is geometry. thus it does not matter whether you create geometries on or below ground. though, so there's no specific distinction between the two.
though I don't know of a specific project which has been done with the CE yet. your chance ! 🙂
AndyTan
Appreciate your reply. I will get working on it. 😄
MatthiasBuehler1
sure. let me know if you need any specific input.
things may need some workarounds since you need sometimes some strategies to work with procedural modeling. but I'm pretty fluent in CityEngine, so I probably will be able to give you some hints in the best direction. k ?
