Attributes
2620
04-14-2014 07:08 AM
LukeCzar
I was trying to export my scene with some metadata, in the Rule file I specified which attributes I wast to use in WebScene, but the WebScene still shows all the attributes
[ATTACH=CONFIG]33071[/ATTACH]
Is there anything I can change in CE options?
Lukasz
MatthiasBuehler1
Hi !
Exporter dialog > Object metadata > None..
ok ?
m.
LukeCzar
When I select "none" there is no data at all, maybe there is something wrong with my data? Previously it was working (different data)
but in this case not
Lukasz
MatthiasBuehler1
And the other options ?
I'm not sure what the actual issue is, I'd need more precise details..
matt
