Ask for help about prt::FlexLicParams
1628
06-06-2017 09:15 AM
LuoSherlock
I am writing to ask for help.
When I use CityEngine 2014.0 to construct the rule base, here comes the problem that prt::Status shows STATUS_NO_LICENSE.
I have tried my best to solve it, but it does not work.
Some background information that may be useful as following:
prt::FileLogHandler shows:
[2017-Jun-05 15:58:28.135212] [info] ESRI Procedural Runtime
[2017-Jun-05 15:58:28.135212] [info] Version: 1.1.1471 | Build Date: Thu 05/22/2014 03:15 AM | Build Config: PRT_BC_REL PRT_CC_OPT PRT_TC_VC10 | OS: win32
[2017-Jun-05 15:58:28.135212] [debug] looking for loader library at path C:\CodePrjs\Win32_CityEngine_frame\x64\Debug
[2017-Jun-05 15:58:28.166436] [fatal] The licensing system could not be initialized, please verify your 'LicParams' data.
[2017-Jun-05 15:58:28.166436] [error] prt::init failed, exception caught: 'No license.'
[2017-Jun-05 15:58:28.166436] [error] Status code = 3 = No license.
Develop environment:
OS: Windows Server 2012 R2 Standard 64-bit
IDE:Visual Studio 2013 Ultimate 2013 Version 12.0.21005 REL
CityEngine Version:2014.0 advanced 64-bit:
*** System properties:
3dview.show_trimplanes_normals=false
CITYENGINE_CONFIG=TRUE
CITYENGINE_FEATURE=CityEngAdv
[email protected]
LICTIME=4070937600371
SEAT_PREFERENCE_CITYENGINE=Float
SOFTWARE_CLASS_CITYENGINE=Advanced
Our code:
prt::Status _status = prt::Status::STATUS_UNSPECIFIED_ERROR;
prt::FlexLicParams _flex_licparams;
_flex_licparams.mFeature = "CityEngAdv";
_flex_licparams.mHostName = "[email protected]";
//_flex_licparams.mFeature = "CityEngAdvFx";_flex_licparams.mHostName = "";
_flex_licparams.mActLibPath = "C:\CodePrjs\Win32_CityEngine_frame\x64\Debug\flexnet_prt.dll";
//_flex_licparams.mActLibPath = "C:\Program Files\Esri\CityEngine2014\plugins\com.esri.prt.clients.ce.win32.win32.x86_64_1.0.0\flexnet_prt.dll";
const wchar_t * extensions = L"C:\\Program Files\\ESRI\\CityEngine2014\\plugins\\com.esri.prt.clients.ce.win32.win32.x86_64_1.0.0\\lib";
const prt::Object * licenseHandle = prt::init(&extensions, 1, prt::LOG_DEBUG, &_flex_licparams, &_status);
I really appreciate if you can help me solve this problem or tell me what should I do.
Looking forward to your reply.
Tags (1)
ThomasFuchs
Have you installed a matching version of the CityEngine Administrator on your system? Its licensing service is needed.
esri-cityengine-sdk/README.md at master · Esri/esri-cityengine-sdk · GitHub
LuoSherlock
Yes,I have installed CityEngine 2014.0 already,and SDK(1.1.1471) matched with it,and the software could  be start normally.Is there any other reason it can be?
SimonHaegler
does it work in release mode?
