Adding base shape colour to Plant_Loader.cga
1976
06-30-2020 08:17 PM
by Anonymous User
Not applicable
I have managed to successfully add a generic brown (mulch) colour to the Plant_Distributor.cga by adding GroundCover to the existing rule:
@StartRule
Generate -->
case Mix == "Custom":
alignScopeToAxes(y)
comp(f){ vertical: NIL | bottom: NIL | all= CustomMix }
GroundCover
else:
alignScopeToAxes(y)
comp(f){ vertical: NIL | bottom: NIL | all= Generate(_getMix) }
GroundCover
GroundCover -->
color("#948477")
This works and adds a brown base colour to the shapes.
When I try to do that to Plant_Loader.cga with:
@StartRule # assumes that all main attributes have been set outside
Generate -->
case Height > 0:
set(_plantNbr,_indexFromCommonName(Name))
set(_plantName,_validate(Name))
set(_plantHeight,Height)
set(_plantRadius,Radius)
s(0,0,0) center(xyz)
alignScopeToAxes(y)
TrunkOrigin
GroundCover
else:
Generate(Name)
GroundCover
GroundCover -->
color("#948477")
The Shape does not receive a colour and stays to generic base colour.
Can someone explain what I am doing wrong?
CherylLau
The reason why the ground cover doesn't work in the code above is because the Plant_Loader sets the size of the shape to zero.
I would recommend making a new rule that imports the Plant_Loader instead of modifying the Plant_Loader itself.  That way, if a new version of the Plant_Loader becomes available later, you can update to the new version.  On the initial shape, you can call the Plant_Loader and also create the GroundCover.  The same goes for the Plant_Distributor.
import Plant_Loader:"/ESRI.lib/rules/Plants/Plant_Loader.cga"
Lot -->
	Plant_Loader.Generate
	GroundCover
GroundCover -->
	color("#948477")
CherylLau
Lot -->
	GroundCover
GroundCover -->
	color("#948477")
by Anonymous User
Not applicable
Thanks so much, I really appreciate it!
It can be so simple sometimes!
