adding a shade above the ground floor
1734
07-21-2013 02:06 PM
JoanneO_Brien
Hi
I have a building which I'm trying to put a shade above my ground floor. But I'm getting a slight issue when it goes around corners, so I was wondering if there was a way to have it joining up so it doesn't have the wedge gap shown below??
This is my current code for it:
FrontFacade--> split(y){ 4 : GroundFloor | 0.2 : Shade | {3 : Floor}*| ~1 : Wall}
Shade--> color(wallColour)
 setupProjection(2,scope.xy,scope.sx,scope.sy)
 projectUV(2)
 set(material.dirtmap, walldirt_tex)
 s('1,'1,3)
 i("builtin:cube")
RafałPerzyna
Hi Joanne,
i'm not sure if there is some straight way to fill that hole...
Maybe try to split Shade
comp(f) {front : FrontShade | back : BackShade |right : SideRightShade | left : SideLeftShade |top: RoofShade |bottom : BottomShade}
and later
 SideLeftShade-->
extrude(1)
 SideRightShade-->
extrude(1)
it isn't best solution, but maybe will give you some tips
or just insert some corner object made in for eg blender
Rafal
JoanneO_Brien
Hi
Thanks for your suggestion. Because it's a generic model run for a lot of different buildings I wouldn't be able to insert some blender object as this would be different for every model but it gave me some ideas, and actually fixed another little issue I'd forgotten about.
Anyway in the end I decided that rather than assigning the shade to all the front facades, I added a case function that extruded the facade only for the first edge, and left the others empty. Not perfect but that'll do for now 🙂
