try: for cga
2911
11-21-2022 09:39 AM
romainjanil
Hi, this is a thing which is in my unformulated wish list for a long time.
Wondering if it would possible to have something similar to the try | except python version, but in cga.
This would be mainly for geometrical manipulation operators which "silently" fail to process a rule geometry (thinking of roofs in certain weird cases, offsets, setbacks etc). When that happens there's no way -in cga, for example with some case/else- to catch those errors because derivation stops at faulty shape and keeps input geometry in its current state (meaning if at beginning of a rule set, most of the cases without a proper material, name etc).
Of course these problems are somehow catchable in cga log afterwards, but I think (imho) it would really streamline and robustify generation process when dealing with massive batches.
Anyway, this is not urgent...
3 Comments
CherylLau
It's not what you asked for, but resetGeometry might be able to help in some (probably not all) cases (though it might be tedious).
https://doc.arcgis.com/en/cityengine/latest/cga/cga-reset-geometry-operation.htm
romainjanil
HI , no unfortunately, it's impossible to catch those pure geometrical error at the moment, as I said derivation stops and leaves rule geometry -as is- as a terminal leaf. No matter what you code after. This is a very special tricky usecase, I should probably package an exemple.
ChristianIten
