Map Layers in Comparison Reports
1166
02-27-2024 09:42 AM
ArielLow2146
Is there a way to include data from map layers in comparison reports?
FasilTiru
Hi @ArielLow2146
Using web map layer attributes directly in comparison reports is not currently supported due to some technical limitations. The recommended workflow is to create a custom data with your map layers and use the variables in comparison reports.
Learn more about custom data
Cheers,
Fasil T.
ArielLow2146
@FasilTiru thank you for this suggestion. I considered custom data but I don't want the data to be aggregated and I can't seem to find a way to turn off aggregation when configuring a custom data variable. Is there a way to accomplish this?
