Infographic table shows wrong values
1121
04-11-2023 08:26 AM
JeffreyEngstrom
I am authoring an infographic report with a table. I have added multiple different variables to the table in report builder. But when I run the report, it fills all the rows with values from a single variable. How do I fix this bug?
The numbers below should all be different:
CherylHagevik
Hi @JeffreyEngstrom Thanks for reaching out with your question. It looks like you are working with your own custom data to create this table, so it may be best to contact Esri Support for additional assistance. However, if you would like to share additional details on how you set up your custom data and table, I will be happy to take a quick look.
Also, here is blog with helpful information on working with your own data - Best practices when sharing and running infographics with your own data
