Currently, Business Analyst Web App allows users to to create custom variable based on fields/attributes from a data layer.
However, is it possible to create a variable that is not from a data layer, e.g. a constant? A use case is where I want to derive a value in my Report by multiplying a data field by a fixed number. It currently seems that I must also create a field to hold the multiplier. Is this actually the case or am i missing a functionality?
Hi Abel,
You should be able to create the desired custom variable by the following workflow:
Please let me know if this workflow accomplishes your desired customer variable and properly answers your question.
Thank you for using Business Analyst Web.
Best Regards,
Donna
