BA Spatial Join Question
1129
06-28-2018 02:54 PM
BrandonPowell1
Hi All,
I've got a spatial join question and I hope it makes sense. I've got a set of 8 block groups and I want to know what county they are inside. When I do a spatial join (intersect/one-to-one), I'm getting an output of 8 block groups back, but the county is not correct. 6 of the block groups should be in Yuma County, CO but I'm getting counties that should be in Yuma county saying that they are in a county that is next door. Any idea how I can fix this or what I'm doing wrong? I opened a ticket with ESRI just now and the analyst worked on it for almost an hour and couldn't figure it out. He tried a bunch of different spatial joins, etc.
Jason_RobinsonRobinson
Brandon,
I assume you got this sorted out a while back but for any others find this it is pretty straight forward finding out what county a block group is in as long as it has a 12 digit FIPS code.  The attached image shows the break down of a block groups FIPS code.
Regards,
Jason R.
12 Digit FIPS break down (block group)
