Sharing some functions that could be added for further arcade enhancements
1178
01-14-2025 09:59 AM
RPGIS
by MVP Regular Contributor
The functions below work for ArcGIS Enterprise 10.8 and later. I have used these two functions quite often since these automatically account for matching field names but don't account for field types.
// Get matching field names found in both lists
function GetMatchingFields( FieldListA, FieldListB ){
var MatchingFields = Null
var separator = ','
// Loop through the list of field names in list A
for ( var a in FieldListA ){
for ( var b in FieldListB ){
if ( FieldListA[ a ] == FieldListB[ b ] ){ MatchingFields += FieldListA[ a ] + separator }
if ( IsEmpty( MatchingFields ) == False ){ MatchingFields = split( MatchingFields , separator ) }
return MatchingFields
// Get field names from input features
function GetFieldNames( InputDictionary , OmitFields ){
var FieldNames = Null
var separator = ','
for ( var field in InputDictionary ){
// Populate the specified list with the field name
var keep = True
for ( var i in OmitFields ){
if ( field == OmitFields[ i ] ){ keep = False ; Break }
if ( keep == True ){ FieldNames += field + ',' }
if ( IsEmpty( FieldNames ) == False ){ FieldNames = split( FieldNames , separator ) }
return FieldNames
The functions below were updated to use on Enterprise 10.9 and later.
    var MatchingFields = []
        if ( Includes( FieldListB , a ) ){ Push( MatchingFields , a ) }
    if ( Count( MatchingFields ) == 0 ){ MatchingFields = Null }
function GetFieldNames( InputFeature , OmitFields ){
    if( TypeOf( InputFeature ) == 'Feature' ){ InputFeature = First( InputFeature ) }
    var FieldNames = []
    for ( var field in InputFeature ){
        if ( !Includes( OmitFields , field ) ){ Push( FieldNames , field ) }
    if ( Count( FieldNames ) == 0 ){ FieldNames = Null }
    return FieldNames
It would be nice if functions like these were added to the library of functions in arcade since it is fairly standard and would be easier to use.
DavidColey
MVP Frequent Contributor
Hi @RPGIS - I'm assuming these work with the datastore profile, but otherwise where are you using this?  As an attribute rule? Does this set up a field map for an append or data load op?
RPGIS
I use this as part of an attribute rule for the most part but it I have yet to test it in other places such as dashboards. It's mostly a data load operation, similar to using append with field map.
