Using API key with QML
1684
07-26-2021 12:04 AM
MarkC1
Is there any examples of how to implement an API Key with QML. The two examples in the documentation (link below) but both appear to be the same and for C++. Is it only supported for C++?
https://developers.arcgis.com/documentation/mapping-apis-and-services/security/tutorials/create-and-...
ErwinSoekianto
Esri Alum
@MarkC1
The API Key is supported in both C++ and QML in ArcGIS Runtime SDK for Qt, thank you for pointing out the issue with the documentation.
This is the doc (also has some c++ issue in the sample),
- Setting up app level API Key , https://developers.arcgis.com/qt/qml/api-reference/qml-esri-arcgisruntime-arcgisruntimeenvironment.h... .
- Setting up API Key for RouteTask, https://developers.arcgis.com/qt/qml/api-reference/qml-esri-arcgisruntime-routetask.html
I hope this is helpful.
Erwin
ErwinSoekianto
Esri Alum
@MarkC1
Erwin
