Suggestions in the Locator Service
2127
09-13-2016 07:07 AM
RafaelFernandez1
Hi there,
I am trying to implement a ServiceLocator using QML (AppStudio). It works great in a general sense as you can see below:
ServiceLocator working with a local service
However I miss the suggestion property I used to have when I worked with the javascript API. I was having a look at the QML API but I am not able to see any word about suggestions.
Any clue?
Rafael Fernandez
nakulmanocha
This is being implemented in the next major release "Quartz"
SuggestListModel QML Type | ArcGISQtQML Quartz
Until then, the only option you have is to make a NetworkRequest to get the suggestions from the World geocoding service.
 property url serverURL: "https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer/suggest?f=json&text=3&maxSuggest..."
    NetworkRequest { id: networkRequest
        url: serverURL
        responseType: "json"
        onReadyStateChanged: { if ( readyState === NetworkRequest.DONE ) { jsonText.text = JSON.stringify(response, undefined, 2); } else { jsonText.text = readyState; } }
I haven't tried yet but you can make a new request onTextChanged signal
nakulmanocha
        url: serverURL
nakulmanocha
Hi Rafael,
I have found a sample which demonstrates the custom implementation of  world geocoding suggestions request as I talked before.
I hope this helps.
Nakul
