In Map Viewer's map page, there is a behavior that the basemap is exhibiting which seems like a bug.
If I change the basemap to "Imagery" or "Imagery with Labels", and tap on a feature (belonging to a vector layer in the webmap), the imagery tile data is also added to the attributes list. Not sure if this is intentional, but in my experience, most use cases of Map Viewer or any map interaction do not require seeing metadata for imagery. This can also be replicated by simply tapping on the imagery basemap. See below screenshot.
If I were also clicking on a geometry point feature in this area, I would have 43 different items in my attributes list to navigate through. This is a pain to interact with.
Any plans on fixing this in a future update? My current plan is to fix this within the code and re-deploy Map Viewer to our current applications that use the template.
Thank you!
Application Developer, GeoMarvel
