Map Viewer Template(QT) not able to search for features from offline mmpk
909
08-29-2018 02:24 AM
KamranYusaf1
I have created an app using the Map Viewer template. I am using a mmpk and its working. I have one issue though: I am not able to use the 'search' function and search for the features. I always get the mesage 'No result found for feature'. Is there a certain way the mmpk should be setup to allow the search? Or do anyone have a suggestion for why the search isn't working?
I am using the newest template(Appstudio 3.0)
Any help will be appreciated
Best Regards
Kamran
ErwinSoekianto
Esri Alum
Kamran,
Is it possible for you to share the MMPK item id that you are using if it is public? So that we can see what's wrong.
If this is not possible to share, it is probably best to call Esri Technical Support so that we can help troubleshoot this.
Thank you,
Erwin
KamranYusaf1
Hi Erwin,
Thanks for your quick reply. I realised that i need to have a locator in the mmpk for the search function to work. I didn't have that. So i believe this is the issue?
Best Regards
Kamran
