How to push a text string in a StackView
3085
11-22-2018 10:58 AM
GiatriLalla
Good Day,
I understand that a page in stackview can be pushed by the code below for example:
StackView {
   anchors.fill: parent
   initialItem: startPage
Component {
   StartPage {
   onNext: {
      stackView.push (page2);
} etc.
How can a text string be pushed in stackview from one page to another? Thank you.
StephenQuan1
Not entirely sure I understand your question. Can you provide more information? What is this string? A stackview can only have pages pushed to it. Is this text string a parameter on the page? If you give an explanation to the problem you're trying to solve we can better help you.
JaysonWard
Hi Giatri:
I think what you want to do is assign a text string property on one view with a text string property from another view. You pass parameters in the push method after the id of the view being pushed onto the stack.
 stackView.push (page2, { "propertyNameSetOnPage2": "the string you want to pass to page 2"});
In that example on Page 2 you would have:
property string propertyNameSetOnPage2
and when the view is pushed onto the stack, that property will get set to "the string you want to pass to page 2"
See: StackView QML Type | Qt Quick Controls 2 5.11
