Generate Geodatabase
3158
12
01-06-2020 06:18 AM
jaykapalczynski
Honored Contributor
I am using the template example in appstudio to test downloading a geodatabase.  Its working as it seems it should but I have a question that maybe someone can help answer
In the example it is setting up some Geodatabase Parameters.  One of these is the Bounding box that the user specifies and as such all features within this box are downloaded to the Geodatabase.
My question.  Can I add w where clause anywhere in there?
// create the generate geodatabase parameters
GenerateGeodatabaseParameters {
    extent: generateExtent
    outSpatialReference: SpatialReference.createWebMercator()
    returnAttachments: false
I tried this but getting errors...
QueryParameters {
    whereClause: "created_user = 'Law'"
    QueryParameters: params
jaykapalczynski
Honored Contributor
So like this?  whats the "new" for ?
var startDate = new Date(2019-03-24);
or this
var startDate = new Date( ' 2019-03-24 ' );
by Anonymous User
Not applicable
Suggest you have a read up on javascript dates if you need help creating them....
Date - JavaScript | MDN
JavaScript Date Objects
You don't have to use a date object, you can just use the date strings. I just find it easier and more consistent to work with date objects and convert them back to ISO strings.
jaykapalczynski
Honored Contributor
The big problem for me is trying to figure out how ESRI wants the format to look to search its date field.  The syntax that is.  As I stated above I can get the date format correct for the DefinitionExpression but the same format does NOT work for the GenerateLayerOption...
If I can figure out how ESRI wants the date to appear and can get that working I can reverse engineer the date field and variable from there....why does one syntax work for the DefinitionExpression and not work for the GenerateLayerOption?
