Filter Data Geodatabase
1938
6
12-26-2019 11:04 AM
jaykapalczynski
Honored Contributor
I have a local .geodatabase on my mobile device.  I can read it fine.
I am now attempting to set a where clause or filter that allows the user to click a button and filter / ONLY show data that is there based on the Created_User field
Can I just set a WHERE clause in the Geodatabase or do I nee to do something else...
I would like to be able to click the button to just show that specific persons from the field and then click the button again and go back to ALL data.
Thoughts?
                FeatureLayer {
                    visible: false
                    featureTable: gdb.geodatabaseFeatureTablesByTableName["Hunting"]
                    // create the geodatabase
                    Geodatabase {
                        path: Path
                        onErrorChanged: errorMessage = error.message;
ErwinSoekianto
Esri Alum
I would assume, it would be the same as how you would put the query parameter for the REST end point of the feature layer. Querying Feature Services: Date-Time Queries
cc: ArcGIS Runtime SDK for Qt
jaykapalczynski
Honored Contributor
Im trying this but not sure because I am using a local geodatabase and think my syntax might be incorrect
It removes all of the records when I click the button and then turns them all on
BUT its removing them all and I know there are a couple different values in the created_user field.
thoughts?
                    Button {
                        text: "Apply Expression"
                        enabled: gdb.loadStatus === Enums.LoadStatusLoaded
                        onClicked: {
                            Points.definitionExpression = "created_user = \'ESRI_Anonymous\'"
                    Button {
                        text: "Reset"
                        onClicked: {
                            Points.definitionExpression = "";
jaykapalczynski
Honored Contributor
Think I have it...just syntax...
what are the \ used in his example
Feature layer definition expression | ArcGIS for Developers
How can I make a LIKE statement
onClicked: {
   Points.definitionExpression = "created_user = 'Law'"
jaykapalczynski
Honored Contributor
Does this look correct?  Seems like I could make this look nicer but this seems to work.
"created_user = " + "'" + credentialUsersNameNew + "'" + " AND PublicPrivate = 'public'";
Last question....any idea how to query between specific dates?
jaykapalczynski
Honored Contributor
I am trying this but no luck
This is trying to query the created_date that is created automatically
var startdate = "12/18/2019 1:30:10 AM";
Points.definitionExpression = "created_date >= " + " ' " + startdate + " ' ";
Does a .geodatabase file follow SQL standards?
preferably I would simply like to query for a specific year....
i.e. show me the records for 2018 or 2019
ErwinSoekianto
Esri Alum
jaykapalczynski
Honored Contributor
OK great...yea wanted to know if it follow standard SQL....looks like it does....Cheers
