FeatureService with different spatialreference
3025
06-15-2016 03:06 AM
RamiGhali2
Hello,
In AppStudio, desktop edition, Is it possible to add FeatureService with a spatial reference different from the basemap's ? If yes, how can I do that ?
I tried the below QML but the featureservice doesn't show !
Map {
        anchors.fill: parent
        extent: envelopeInitalExtent
        wrapAroundEnabled: true
        rotationByPinchingEnabled: true
        magnifierOnPressAndHoldEnabled: false
        mapPanningByMagnifierEnabled: true
        zoomByPinchingEnabled: true
        //INITIAL EXTENT
        Envelope {
            xMax: -13630134.691272736
            yMax: 4554320.7069897875
            xMin: -13647294.804122735
            yMin: 4535211.44991852
            spatialReference: mainMap.spatialReference
        //BASEMAP
        ArcGISTiledMapServiceLayer {
            url: appWindow.info.propertyValue("basemapServiceUrl", "http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer")
        //CREATE A FEATURE SERVICE TABLE FROM A FEATURE SERVICE
        GeodatabaseFeatureServiceTable {
            url: "MY_FS_URL"
        FeatureLayer {
            featureTable: featureServiceTable
Thanks.
LucasDanzinger
Esri Frequent Contributor
Yes, this should work. A couple of key points:
  1. The map takes on the spatial reference of the first layer added, so if you first add a tiled map service layer that is in WKID 102100, that is what your Map will now be in (just like how the data frame in ArcMap behaves)
  2. If you add in a FeatureLayer pointing to a Feature Service, it'll automatically request features be returned in the spatial reference of the map. So if your first layer is in 102100, and you add a feature layer pointing to a feature service in 4326, it'll request the features be returned from the server in 102100, and should then display on the map
  3. There is no need to set the spatial reference of the feature table like you are doing in the above code. The layer will figure out what the map's spatial reference is, and automatically request features to be returned in that spatial reference.
- Luke
LucasDanzinger
- Luke
RamiGhali2
Thank you Lucas for your reply.
What I found is that the FeatureService I'm trying to add is secured so, it needs authentication before being able to display it !
nakulmanocha
Yes it should work just fine unless you are adding a local (offline) geodatabase and in that case it should be in same spatial reference as the basemap. I tested the following code and works fine
            url: "http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"
            url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Water_Network/FeatureServer/23"
FeatureLayer {
