Default Repeat count starts with 0 instead of 1?
2376
03-03-2017 01:21 PM
TL2
I am hoping someone can help me alter the Survey123 code so that the default repeat begins with this...
Instead of this...
JamesTedrick
Esri Esteemed Contributor
Hi Tucker,
If you configure a repeat with the appearance of 'minimal', you get the behavior you're asking for.
RobertScheitlin__GISP
Tucker,
   I am pretty sure you have this question posted in the wrong space/group. I am not familiar with survey123 but if it is an app thats code base comes from AGOL then code modification can not be done unless you are hosting the app on your own server (if that is even possible, as I said I am unfamiliar with survey 123). Either way this question does not have anything to do with Web AppBuilder.
https://community.esri.com/groups/utility-survey-123-configurations?sr=search&searchId=45ea0bc0-a849...
https://community.esri.com/groups/survey123?sr=search&searchId=45ea0bc0-a849-45ef-942a-0d5e43286056&...
TL2
Meant for AppStudio.  Thanks.
JamesTedrick
Hi Tucker,
