Debug build failing for Android
2215
03-07-2024 11:32 PM
AnshulUpadhyay
I have implemented the jacoco coverage report for my android app. Since i have implemented it and try to build the debug app and run the jacoco commands to generate reports i am getting below issue .
Please suggest the solution for it.
* What went wrong:
Execution failed for task ':app:mergeExtDexStagingDebug'.
> Could not resolve all files for configuration ':app:stagingDebugRuntimeClasspath'.
> Failed to transform arcgis-android-100.15.0.aar (com.esri.arcgisruntime:arcgis-android:100.15.0) to match attributes {artifactType=android-dex, asm-transformed-variant=NONE, dexing-enable-desugaring=true, dexing-enable-jacoco-instrumentation=true, dexing-is-debuggable=true, dexing-min-sdk=23, org.gradle.category=library, org.gradle.libraryelements=jar, org.gradle.status=release, org.gradle.usage=java-runtime}.
> Execution failed for JacocoTransform: /Users/c_anshul.kumar/.gradle/caches/transforms-3/d6ba30801faee8e20758aebedab4fe91/transformed/jetified-arcgis-android-100.15.0-runtime.jar.
> org.gradle.internal.operations.BuildOperationInvocationException (no error message)
* Try:
> Run with --stacktrace option to get the stack trace.
> Run with --info or --debug option to get more log output.
> Run with --scan to get full insights.
2: Task failed with an exception.
* What went wrong:
Execution failed for task ':app:mergeLibDexStagingDebug'.
> Failed to transform classes.jar (project :Libraries:libraryjourneyflow) to match attributes {artifactType=android-dex, asm-transformed-variant=NONE, com.android.build.api.attributes.AgpVersionAttr=7.4.2, com.android.build.api.attributes.BuildTypeAttr=debug, com.android.build.gradle.internal.attributes.VariantAttr=debug, dexing-enable-desugaring=true, dexing-enable-jacoco-instrumentation=true, dexing-is-debuggable=true, dexing-min-sdk=23, org.gradle.category=library, org.gradle.jvm.environment=android, org.gradle.libraryelements=jar, org.gradle.usage=java-runtime, org.jetbrains.kotlin.platform.type=androidJvm}.
> Failed to transform arcgis-android-100.15.0.aar (com.esri.arcgisruntime:arcgis-android:100.15.0) to match attributes {artifactType=jacoco-classes-jar, org.gradle.category=library, org.gradle.libraryelements=jar, org.gradle.status=release, org.gradle.usage=java-runtime}.
JanGodlewski
Hi Anshul, were you able to fix the issue?
JanGodlewski
I have similar issue unfortunately
smithcarl
This usually happens when Jacoco instrumentation conflicts with certain dependencies—try excluding Jacoco from those specific libraries or align Gradle/AGP versions to avoid the transform issue. I ran into a similar headache recently, and fixing the version mismatch solved it. By the way, your post was really useful to read while I was relaxing with my Plush Labubu Keychain—small things like that make debugging a bit less stressful.
