Android Local Build Failing
1113
08-10-2023 11:56 AM
MKa
I have other posts about the tools needed to build.  But I don't know if the wrong install tools on windows are what is causing the local build to fail.  I have installed qt 5.15.6 and some of the required tools (I think they are right), but when I run the build it continues to fail at this point near the end of the build.
Updating Android package files with project settings.
  -- res/values/libs.xml
  -- AndroidManifest.xml
  -- res/values/strings.xml
Exception in thread "main"
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.ssl.Alert.createSSLException(Alert.java:131)
