Zoom
1500
7
04-25-2011 09:22 AM
JayKappy
In my app i have a PID value search.  It finds the PID value (finds the Land Parcel) and zooms to that Parcel.  Whiles this is happening I run another series of Querys that Buffer the Parcel and find records, addintially I do a series of spatial queries to find other data.
Everything works great but my zoom is only aware of the original Parcel found...At any one point I have two graphic layers beign displayed on the map....the Main Parcel and one of the other features, BUT only 2 at a time...
Is there a way to test wether or now a Graphic Layer is visable and if visialbe zoom to that layers extent?
JayKappy
I am horsing around with this.....getting soemthing to zoom to the extent of a graphics layer
Missing syntax here.....AND dont even know if I can do this...
        Dim graphicsLayer As GraphicsLayer = TryCast(MyMap.Layers("MyGraphicsLayerSearch"), GraphicsLayer)
        ' Zoom to selected feature (define expand percentage)
        Dim ZoomTographicslayer As ESRI.ArcGIS.Client.Geometry.Envelope = graphicsLayer
        Dim expandPercentage As Double = 230
        Dim widthExpand As Double = ZoomTographicslayer.Width * (expandPercentage / 4)
        Dim heightExpand As Double = ZoomTographicslayer.Height * (expandPercentage / 4)
        Dim displayExtent As New ESRI.ArcGIS.Client.Geometry.Envelope(ZoomTographicslayer.XMin - (widthExpand / 2), ZoomTographicslayer.YMin - (heightExpand / 2), ZoomTographicslayer.XMax + (widthExpand / 2), ZoomTographicslayer.YMax + (heightExpand / 2))
        MyMap.ZoomTo(ZoomTographicslayer)
Can I simply Zoom to graphics Layer?
JayKappy
Think I got it
        Dim l_Parks As GraphicsLayer = TryCast(Me.MyMap.Layers("MySelectionGraphicsLayerParks"), GraphicsLayer)
        l_Parks.Visible = True
        ' Zoom to feature (define expand percentage)
        Dim ZoomTographicslayer As ESRI.ArcGIS.Client.Geometry.Envelope = l_Parks.FullExtent
BUT in one case I have 2 Graphic layers drawing.....one Polygon and one Point feature.....Can I combine the Geometry/Extent of the two AND THEN zoom to that?
Is there any way to zoom to the extent of 2 different Graphic Layers......being different FC types (point, line, poly)?????????
TerryGiles
The Envelope class has a Union method which you could try to use to get the full extent of both layers.. you may need to check the extent of the graphics layers containing 1 point though, as it my not have a valid extent.  If that's the case, just fake it by creating a new envelope centered on the point w/ the width & height set to 1 foot or meter or some other appropriately small value.
below is a C# example of using the union method.   Hope it helps, TG
                      //zoom to all features returned by the query task
                        Envelope extent = fs.Features[0].Geometry.Extent;
                        foreach (Graphic g in fs.Features)
                            extent.Union(g.Geometry.Extent);
                        Map.ZoomTo(extent);
JayKappy
Not really following on the Union....I need to specifiy two Graphic layers that are in the map by name then union them and get the extent....
I am doign the zoom thing when the user hovers over a specific tab in a tab control...this is where I am turing on specific layers and zooming to them...
But do hear you on the point and not having a valid extent...I am running into that already...so I guess I have to start there...and then worry about the above...not really finding that or familiar with that in any way....can I do this on the fly when the Graphic point is created?
Dim l_PointOne As GraphicsLayer = TryCast(Me.MyMap.Layers("MySelectionGraphicsLayerPoint"), GraphicsLayer)
Dim l_polygon1 As GraphicsLayer = TryCast(Me.MyMap.Layers("MySelectionGraphicsLayerPoly"), GraphicsLayer)
'Then do some sort of Union and get the extent??????????????
TerryGiles
the GraphicLayers have a FullExtent property which returns an Envelope.  These 2 envelopes can be unioned to get the full extent of both layers.  In general like this ..
'make sure the extent from the point graphics layer is valid otherwise create one here
Dim NewExtent as Envelope = l_polygon1.fullextent.union(l_pointone.fullextent)
MyMap.ZoomTo(NewExtent)
JayKappy
Thanks a ton....have to work on getting the extent of the point valid, but have a very solid base to work from ...thank again....
Here is a point....am I on the right path to Defien a new envelope for it as you mentioned..
        ' Turn On Layer
        Dim l_PoliceHQBuffer As GraphicsLayer = TryCast(Me.MyMap.Layers("MyGraphicsLayerPoliceHeadQuaters"), GraphicsLayer)
        l_PoliceHQBuffer.Visible = True
        Dim ZoomTographicslayer As ESRI.ArcGIS.Client.Geometry.Envelope = l_PoliceHQBuffer.FullExtent
        Dim Width As Double = 1
        Dim Height As Double = 1
        Dim expandPercentage As Double = 5
        MyMap.ZoomTo(displayExtent)
JayKappy
Got it....was staring me right in the face....Thank you for the Union code and the directional push
THANKS A BUNCH....VERY APPRECIATED...
        ' Turn On Layer
        Dim l_Precinct As GraphicsLayer = TryCast(Me.MyMap.Layers("MySelectionGraphicsLayerPrecincts"), GraphicsLayer)
        l_Precinct.Visible = True
        Dim l_PrecinctPt As GraphicsLayer = TryCast(Me.MyMap.Layers("MySelectionGraphicsLayerPrecinctsPts"), GraphicsLayer)
        l_PrecinctPt.Visible = True
        ' SET EXTENT AND BACK OUT ZOOM OF THE PRECINCT PARCEL
        Dim ZoomTographicslayer As ESRI.ArcGIS.Client.Geometry.Envelope = l_Precinct.FullExtent
        Dim displayExtentPrecinct As New ESRI.ArcGIS.Client.Geometry.Envelope(ZoomTographicslayer.XMin - (widthExpand / 2), ZoomTographicslayer.YMin - (heightExpand / 2), ZoomTographicslayer.XMax + (widthExpand / 2), ZoomTographicslayer.YMax + (heightExpand / 2))
        'MyMap.ZoomTo(displayExtent)
        ' REDEFINE THE EXTENT OF THE SINGLE POINT
        Dim ZoomTographicslayer1 As ESRI.ArcGIS.Client.Geometry.Envelope = l_PrecinctPt.FullExtent
        Dim Width As Double = 15
        Dim Height As Double = 15
        Dim displayExtentPrecinctPt As New ESRI.ArcGIS.Client.Geometry.Envelope(ZoomTographicslayer1.XMin - Width, ZoomTographicslayer1.YMin - Height, ZoomTographicslayer1.XMax + Width, ZoomTographicslayer1.YMax + Height)
        'MyMap.ZoomTo(displayExtent1)
        ' CREATE NEW ENVELOPE AND UNION THE TWO LAYERS
        Dim NewExtent As Envelope = displayExtentPrecinct.Union(displayExtentPrecinctPt)
        ' ZOOM TO THE NEW EXTENT
