Zoom in extent
1053
10-17-2011 11:18 AM
JerryBiedenbender
Is there a way to change the default zoom in extent. My application is not letting me zoom in close enough?
Jerry
dotMorten_esri
Esri Notable Contributor
If you have tiled layers in your map, the Map's MinimumResolution property defaults to the lower tile level. You can override that by setting that number.
Ie. Map.MinimumResolution=0.1; //one pixel is .1 map unit (feet, degrees, meter depending on your spatial reference),
JerryBiedenbender
That's great thank you for the help.
Jerry
