WrapAround makes all MultiPoints move when one point is moved (Silverlight)
1205
03-24-2017 12:31 PM
rogerlamb
I was wondering if anyone experienced the following issue on Silverlight API (know is out of production but looking for advice).
When I create a simple map with wraparound enabled and add 3 MapPoints to the Multipoint to add to the map.  When I pan on the map, when the right most point hits the edge and moves to the other end, all the points move which makes them not viewable until you keep panning the map to make the points in view.
I was wondering if anyone had a solution for this?
Thanks.
