Win 7 Install
1101
12-17-2009 07:04 AM
TedCronin
I can't seem to get 1.1 installed on a Windows 7 desktop.
dotMorten_esri
Esri Notable Contributor
Could you be more specific. Ie. What is the problem? What errors do you see? What's not installing? etc...
For what it's worth most of the dev team runs Win7, so this is probably the most internally tested OS 🙂
TedCronin
Yep, so it does install on Win7, the problem is Norton.  Norton has a Sonor Protection, and that is what is preventing the install to go forward.  Not Sure what Sonor is, but it keeps removing a glb file.  I have stopped Sonor, Installed Successfully, and I am about to turn the Sonor back on to see if everything is ok.
