What is equivalent of Bing maps MapsItemControl
2442
09-30-2014 10:26 AM
IvanDemkovitch
I'm switching out of Bing Maps into ESRI but have hard time finding sample which will do the same thing..
I have layer on top of base map showing position of assets. Data bound via MVVM.
This is code from Bing Maps:
<m:MapItemsControl ItemsSource="{Binding Source={StaticResource WorkLayerData}}">
<m:MapItemsControl.ItemTemplate>
<DataTemplate>
<Canvas>
.... STUFF drawn here.....
</Canvas>
</DataTemplate>
</m:MapItemsControl.ItemTemplate>
</m:MapItemsControl>
I figured that most close is ElementLayer in ESRI Silverlight control, but can't figure out how to bind it to my datasource and achieve similar result.
Any pointers?
dotMorten_esri
Esri Notable Contributor
Take a look at GraphicsLayer in the samples http://esriurl.com/slsdk. This will give you the better performance than ElementLayer. Your datasource would have to be IEnumerable<Graphic> though.
IvanDemkovitch
Finally got it working. I kept my data source as ObservableArray<MyObjectType>
There was issue with bindings on my custom template, so I had to come up with custom converter to get my object from Esri Binding. After than - everything works the same. In case someone has same problem here is code for converter:
public class ObjectToTrackedAssetConverter : IValueConverter
        public object Convert(object value, Type targetType, object parameter, CultureInfo culture)
            if (value == null) return string.Empty;
            var datBinding = value as ESRI.ArcGIS.Client.DataBinding;
            if (datBinding == null) return null;
            return datBinding.Attributes.First().Value as TrackEsriViewModel.TrackedAsset;
        public object ConvertBack(object value, Type targetType, object parameter, CultureInfo culture)
            throw new NotSupportedException();
Obviously, my TrackedAsset object implement INotifyData..
In XAML when I need to bind to my object's properties here is what need to be done:
<esri:GraphicsLayer>
                <esri:GraphicsLayer.GraphicsSource>
                    <esri:PointDataSource
                            ItemsSource="{Binding Source={StaticResource MappedData}}"
                            XCoordinateBinding="{Binding Longitude}"
                            YCoordinateBinding="{Binding Latitude}">
                    </esri:PointDataSource>
                </esri:GraphicsLayer.GraphicsSource>
                <esri:GraphicsLayer.Renderer>
                    <esri:SimpleRenderer>
                        <esri:MarkerSymbol>
                            <esri:MarkerSymbol.ControlTemplate>
                                <ControlTemplate>
                                    <Canvas
                                        DataContext="{Binding Converter={StaticResource ObjectToTrackedAssetConverter}}">
                                        <Button
                                            Style="{StaticResource LooklessButtonStyle}"
                                            Width="{Binding PushpinWidth}" Height="{Binding PushpinWidth}"
                                            Margin="{Binding PushpinMargin}"
                                            Command="{Binding DataContext.SelectedPushpinChangedCommand, ElementName=LayoutRoot}"
                                            CommandParameter="{Binding}"
                                            Cursor="Hand">
                                            <Ellipse
                                                Width="{Binding PushpinWidth}" Height="{Binding PushpinWidth}" Stroke="Black" Fill="{Binding IsGPSDataRecent, Converter={StaticResource BoolToGreenRedBrushConverter}}" StrokeThickness="1">
                                            </Ellipse>
                                        </Button>
                                    </Canvas>
                                </ControlTemplate>
                            </esri:MarkerSymbol.ControlTemplate>
                        </esri:MarkerSymbol>
                    </esri:SimpleRenderer>
                </esri:GraphicsLayer.Renderer>
            </esri:GraphicsLayer>
So, main thing is to set Canvas DataContext to MY object. Then, I get proper command and property routing and everything works just like it was before with Bing maps control. Performance is pretty good too.
