View all ArcGIS Server services layers in a treeview control(WPF)?
5778
18
06-07-2010 07:57 PM
linusang
My application requires to view all my server's services layers, preferably in a treeview control, and the user will then have the ability to choose which layers he wants to add onto the map.
My department has a number of categories in different subfolders. However, ArcGIS server does not allow subfolders creation to organize my department's mxd files.
i've briefly looked at the Table of Content sample. but realize it only show the TOC in mxd files when it is already added onto the map.
So how can i best implement this feature for my WPF ArcGIS app? Any examples or samples or guides would be very much appreciated.
thanks
DominiqueBroux
Esri Frequent Contributor
Sample of a server explorer showing in a treeview a dynamic catalog of the ArcGIS Server map services : http://resources.esri.com/arcgisserver/apis/silverlight/index.cfm?fa=codeGalleryDetails&scriptID=162...
You can also test it live : http://maps.esri.com/serverexplorer/default.htm
linusang
thanks for the link.
however, when i tried putting my server's url, it doesn't work... it shows a exclamation icon....
and will the code work for wpf?
i opened the sln file and there the reference to ESRI.ArcGIS is missing.. where can i find this reference?
DominiqueBroux
It should work if your server is visible from the server hosting the Silverlight application. This is probably not the case if you are using the live link.
The sample is only Silverlight, but I guess it's possible to adapt it for WPF.
This sample is a little bit old. Some namespaces have changed : ESRI.ArcGIS is now ESRI.ArcGIS.Client and it's now no more useful to use the System.Windows.Controls.Toolkit to get a TreeView.
So, you have :
[INDENT]- in the references :[/INDENT]
[INDENT][INDENT]. to replace ESRI.ArcGIS by ESRI.ArcGIS.Client[/INDENT][/INDENT]
[INDENT][INDENT]. to remove System.Windows.Controls.Toolkit[/INDENT][/INDENT]
[INDENT]- in MapServiceInfo.cs :[/INDENT]
[INDENT][INDENT]. to replace using ESRI.ArcGIS.Geometry by using ESRI.ArcGIS.Client.Geometry[/INDENT][/INDENT]
[INDENT]- to add using ESRI.ArcGIS.Client in TileInfoInfo.cs, LayerEventArgs.cs and ServerTreeView.xaml.cs[/INDENT]
[INDENT]- to replace Controls.Toolkit by Controls in ServerTreeView.xaml[/INDENT]
linusang
hi thanks.. managed to run it in WPF...
how can i display the sublayers(feature layer type) in the explorer as well?
DominiqueBroux
Great:)
Concerning the sublayers, MapServiceInfo.Layers is an array of LayerInfo giving the basic information about the sublayers.
So you could display the layers by replacing in Page.xaml, the textbox giving the info about the map cache by a listbox binded to 'MapServiceInfo.Layers' (it's just an example).
                <!--<TextBox Grid.Column="1" Grid.Row="3" Foreground="White" FontWeight="Normal" FontStyle="Italic" TextWrapping="Wrap" BorderBrush="Transparent" Background="Transparent" Text="{Binding Path=MapServiceInfo.SingleFusedMapCache, Mode=OneWay}"/>-->
                <TextBox Grid.Column="0" Grid.Row="3" Foreground="White" FontWeight="Bold" FontStyle="Normal" TextWrapping="Wrap" BorderBrush="Transparent" Background="Transparent" Text="Layers"/>
                <ListBox Grid.Column="1" Grid.Row="3" FontWeight="Bold" FontStyle="Normal" BorderBrush="Transparent" Background="Transparent"
                         ItemsSource="{Binding MapServiceInfo.Layers}" DisplayMemberPath="Name"/>
linusang
Is there a way to retrieve the type of the sublayer? as i need to differentiate between raster and feature layer
DominiqueBroux
Not sure what you mean by the type of the sublayer (raster and feature layer?).
The sublayers are mainly depending on the service.
With a DynamicMapServiceLayer, the rendering is done on the server, and the client is just displaying the image coming from the server.
With a feature layer service, there is no sublayers and the rendering is done on client.
linusang
i would like to add the appropriate layer(raster or feature) on to the map via the server explorer... if the user chooses a raster sublayer to add onto the map, my code should do the appropriate instantiation then add to the map? currently i instantiate a new FeatureLayer(). however when i add a raster layer, it gives me an error... therefore i need to know what type of layer the user choses to add so i can instantiate the appropriate layer?
not sure if that makes sense.... 😛
DominiqueBroux
My understanding is that you need to make the difference between a map server and a feature server in order to know if you need to instantiate an ArcGISMapServiceLayer or FeatureLayers.
Note that the REST API is giving this info. For example looks at : http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Earthquakes?f=pjson
The serverExplorer sample is deserializing this info in the class Service (Property 'Type'), but it's only taking care of MapServer service (when the sample has been done, FeatureServer was not existing yet).
So you have to extent the sample to take care of feature services. Look at the server.cs code:
foreach (Service service in catalog.Services) {
      switch (service.Type) {
            case MapService.TYPE:
