Version 2.1 Installation
2635
12-09-2010 05:23 AM
PaulHuppé
If I install version 2.1, will it leave version 2.0 there, will it ask me to remove version 2.0 first, or will it erase it automatically?
Paul
JenniferNery
The installation should take care of replacing old files and registry updates. However it is always a good practice to uninstall old version prior to installing new version.
PaulHuppé
Ok. That means that I cannot point to one or the other if I wanted to do that.  Thanks for the information.
Paul
dotMorten_esri
Esri Notable Contributor
It's fully supported to have all of them installed side by side. However note that the templates are overwritten, and that VS and Blend will automatically pick up v2.1 (in most cases changing your existing projects as well). If you need to set the references to 2.0, you need to manually add the reference by browsing to them.
PaulHuppé
That is good to know if run into troubles and need to revert.
Paul
